inspirace - tuning
PajaHR
Re: inspirace - tuning
Příspěvek od PajaHR » 23.01.2012 18:46
akorát si takhle nějak nedovedu mlhovky představit bez toho aniž bych je viděl
ICQ: 465088539
Facebook: Paja Hr
r0mik
Příspěvek od r0mik » 23.01.2012 18:47
Focus 2002 RS #1121-radost
Focus 2002 ST170
Smax 2006 2.5T LPG
Smax 2007 2.5T LPG
Smax 2007 2.5T
PajaHR
Příspěvek od PajaHR » 23.01.2012 19:03
ten je luxusní
ICQ: 465088539
Facebook: Paja Hr
r0mik
Příspěvek od r0mik » 23.01.2012 19:10
GR performance custom Petrol tank in boot
Battery in boot
2x bosch 044 fuel pumps
1x 4.0 jag fuel pump used as lift pump
1.5litre swirl pot
Blitz intercooler
Mocal oil cooler and turbo aftercooler
Gr performance inlet manifold
12mm bosch ISCV (for anti-lag)
GR performance "full race" exhsaust manifold
Gt35/40r turbo
Tial 44mm external wastegate
Blitz boost controler
Gr performance twin side exit exhaust system
Cgi closed deck block
Shot peened crank
I beam rods
Cp racing pistons
Custom spec head
Custom spec cams
Custom boost pipes
Stack dash with custom Carbon surround
Knock link pro
inovite wide band
Dta S60 engine managment "with 2 switchable maps"
Gr performance wiring loom
Fuel lab fuel pressure regulator
Siemens 83lb injectors will get replaced with injector dynamics 1200cc ones after its run-in
nortech oil return
group A air filter
fog lights removed
HID headlight conversion
pollybushed all round
std shocks with H&R springs
graphite wheels
removed front crash bar
front splitter
oil cooler bypass water pipe
underdrive belt kit
modified alternator (digital regulator changed for analog reg)
removed A/C and used smaller drive belt
GR performance heat shield (front pannel)
75deg thermostat
inline water temp sensor for stack dash
inline turbo oil feed filter
avon ZZ3 tyres
[youtube]http://www.youtube.com/watch?v=Ebu8FnToaNg[/youtube]
[youtube]http://www.youtube.com/watch?v=twATlDXhDKc[/youtube][youtube]http://www.youtube.com/watch?v=Axlft9TGzeY[/youtube]
Focus 2002 ST170
Smax 2006 2.5T LPG
Smax 2007 2.5T LPG
Smax 2007 2.5T
Zdwora
Příspěvek od Zdwora » 23.01.2012 19:17
Tak to jo, to uz je tuning :gott:
PajaHR
Příspěvek od PajaHR » 23.01.2012 19:21
paráda sama :cooler:
ICQ: 465088539
Facebook: Paja Hr
abris
Příspěvek od abris » 23.01.2012 19:24
Zase "honíš kilowaty" ? :twisted: :palec_nahoru:
Marťas
Příspěvek od Marťas » 23.01.2012 19:45
Vespod mi chybi kardan....takhle to auto nema smysl :?
Byl : Focus ST2 - 213kW
Byl : Freelander 2 S - 118kW
Byl : Fiesta Mk7 - 60kW
Je : Suzuki SV650 - 55kW
Je : BMW 520D - 128kW
karolkopictures
Příspěvek od karolkopictures » 24.01.2012 08:25
ten biely je úžasný KUA :wallbash:
Focus FUTURA 2002
Kuga ST line 4x4 2019
Mondeo Titanium X 2019
r0mik
Příspěvek od r0mik » 24.01.2012 22:09
Focus 2002 ST170
Smax 2006 2.5T LPG
Smax 2007 2.5T LPG
Smax 2007 2.5T
abris
Příspěvek od abris » 24.01.2012 23:08
Buď ukaž co má pod kapotou, a nebo to přesuň do tuzingu :oops:
Zdwora
Příspěvek od Zdwora » 24.01.2012 23:11
Ma dobry cislo :cooler:
Marťas
Příspěvek od Marťas » 25.01.2012 07:23
...ho nalepil obracene :mrgreen:
r0mik
Příspěvek od r0mik » 25.01.2012 20:23
dneska honba za centimetry :D
sic uz se tu kdysi tento objevil, ale nasel jsem kvalitnejsi foto. Nuda, tak jsem hledal focus fora ve svete.
kola Dz exclusive 7.5" a 9" x 16" s pneu 195/40/16
Focus 2002 ST170
Smax 2006 2.5T LPG
Smax 2007 2.5T LPG
Smax 2007 2.5T
Killermama2323
Příspěvek od Killermama2323 » 25.01.2012 20:29
wááááááá 8O ten biely je prekrásny ! 8)
Ford Focus MK1 - 1.8 TDCI - 74Kw - 101PS - Black colour :twisted:
