2 couvačky
pelen
Re: 2 couvačky
Příspěvek od pelen » 20.07.2010 20:48
Pokud je na dvoustopem vozidle jen jedna mlhovka, tak myslim musi byt pri levem okraji, pokud se jezdi vpravo, jinka si mohou v mlze myslet, ze jedou za motorkou. Mrkni se do technicke vyhlasky pro motorova vozidla.
ihrdlick
Re: 2 couvačky
Příspěvek od ihrdlick » 21.07.2010 06:34
Pelene, v červnu jsem byl na STK a měl 2 požadavky : aby byla mlhovka min 250mm nad terénem a pak, jestli má homologaci, což má. Peugeot 206 a Hyundai Getz (novější) jí má taky uprostřed.
pelen
Re: 2 couvačky
Příspěvek od pelen » 25.07.2010 19:43
Rear fog lamps
In Europe and other countries adhering to ECE Regulation 48, vehicles must be equipped with one or two bright red "rear fog lamps" (or "fog taillamps"), which serve as high-intensity rear position lamps to be energised by the driver in conditions of poor visibility to enhance vehicle conspicuity from the rear. The allowable range of intensity for a rear fog lamp is 150 to 300 candelas,[15] which is within the range of a U.S. stop lamp.[5] For this reason, some European vehicles imported to the United States have their rear fog lamps wired as stop lamps, since their European-specification stop lamps may not be sufficiently intense to comply with U.S. regulations, and in North America rear fog lamps are not required equipment. However, they are permitted, and are found almost exclusively on European-brand vehicles in North America — Audi, Jaguar, Mercedes, MINI, Land Rover, Saab and Volvo provide functional rear fog lights on their North American models. The final generation Oldsmobile Aurora also had dual rear fog lights installed in the rear bumper as standard equipment.
Most jurisdictions permit rear fog lamps to be installed either singly or in pairs. If a single rear fog is fitted, most jurisdictions require it to be located at or to the driver's side of the vehicle's centreline — whichever side is the prevailing driver's side in the country in which the vehicle is registered.[15] This is to maximise the sight line of following drivers to the rear fog lamp. In many cases, a single reversing lamp is mounted on the passenger side of the vehicle, positionally symmetrical with the rear fog. If two rear fog lamps are fitted, they must be symmetrical with respect to the vehicle's centreline.[15] Proponents of twin rear fog lamps say two lamps provide vehicle distance information not available from a single lamp. Proponents of the single rear fog lamp say dual rear fog lamps closely mimic the appearance of illuminated stop lamps (which are mandatorily installed in pairs), reducing the conspicuity of the stop lamps' message when the rear fogs are activated. To provide some safeguard against rear fog lamps being confused with stop lamps, ECE R48 requires a separation of at least 10 cm between the closest illuminated edges of any stop lamp and any rear fog lamp.[15]
http://eur-lex.europa.eu/LexUriServ/Lex ... 538:CS:PDF
http://www.hella.com/hella-com-en/asset ... EN_HKG.pdf
Pavel Bečvář
Re: 2 couvačky
Příspěvek od Pavel Bečvář » 16.09.2011 19:44
Ahoj lidi.
Já to mám takhle a zatím žádný problém... :)
Ford Focus combi 1,8i 16V Zetec 115PS. 1999rv. zelená metal. alu.or15 Ford.
pavel.becvar@tiscali.cz
Re: 2 couvačky
Příspěvek od miki21 » 16.09.2011 19:57
Pěkné,ale ty odrazky po stranách dole bych sundal.Moc tam nesedí,ale každého věc :wink:
A klubové podložky nevidím :nunu: :mrgreen:
Pavel Bečvář
Re: 2 couvačky
Příspěvek od Pavel Bečvář » 16.09.2011 22:36
No asi máš pravdu, sundám je.
Když tam nebyla ta mlhovka v porostředku tak to vypadalo docea dobře.
Dík za názor :palec_nahoru:
