P0131: O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
- mivi
Nemáte prosím zkušenost s touto chybou? Dá se z toho logu říci, zda je problém v té lambda sondě?
Před rokem mi ještě na záruku měnili katalyzátor, od té doby byl klid...
Fuel System 1 is: Closed loop, but fault with at least one oxygen sensor - may be using single oxygen sensor for fuel control No
Fuel System 1 is: Open loop - due to detected system fault Yes
Fuel System 1 is: Open loop due to driving conditions (e.g. power enrichment, deceleration enleanment) No
Fuel System 1 is: Closed loop - using oxygen sensor(s) as feedback for fuel control No
Fuel System 1 is: Open loop - has not yet satisfied conditions to go closed loop No
Fuel System 2 is: Closed loop, but fault with at least one oxygen sensor - may be using single oxygen sensor for fuel control No
Fuel System 2 is: Open loop - due to detected system fault No
Fuel System 2 is: Open loop due to driving conditions (e.g. power enrichment, deceleration enleanment) No
Fuel System 2 is: Closed loop - using oxygen sensor(s) as feedback for fuel control No
Fuel System 2 is: Open loop - has not yet satisfied conditions to go closed loop No
Calculated LOAD Value 37,6470588235294 %
Engine Coolant Temperature 84 Deg C
Short Term Fuel Trim - Bank 1 0 %
Long Term Fuel Trim - Bank 1 -9,375 %
Intake Manifold Absolute Pressure 43 kPa
Engine RPM 961 Rpm
Vehicle Speed Sensor 0 Kph
Ignition Timing Advance for #1 Cylinder 1,5 Deg
Intake Air Temperature 46 Deg C
Time Since Engine Start 131 s
Fuel Rail Pressure 3090 kPa
Commanded Evaporative Purge 0 %
Fuel Level Input 32,5490196078431 %
Barometric Pressure 100 kPa
Control module voltage 14,139 V
Relative Throttle Position 2,35294117647059 %
Commanded Throttle Actuator Control 3,92156862745098 %
Desired Engine Speed 950 Rpm
Oxygen Sensor (O2S) Voltage Bank 1 Sensor 2 0,9716796875 V
Source Of Torque Control Request Torque Controlled For Engine Idle Speed
Elapsed Time Of Current (Or Most Recent) Engine Off Period - Corrected 733 s
Cylinder Head Over Temperature Condition Indicator Is Commanded On False
Cylinder Head Temperature (CHT) Sensor Input Is Currently Unreliable False
Operating In Engine Coolant Temperature (ECT) Sensor Failure Mode False
Operating In EGR (Exhaust Gas Recirculation) System Failure Mode False
EGR Stepper Motor Control Circuit Number 4 Output Fault Detected False
EGR Stepper Motor Control Circuit Number 3 Output Fault Detected False
EGR Stepper Motor Control Circuit Number 2 Output Fault Detected False
EGR Stepper Motor Control Circuit Number 1 Output Fault Detected False
Wheel Profile Has Been Learned For Misfire Monitor True
Currently Misfiring False
Operating In Mass Air Flow (MAF) Sensor Failure Mode False
Operating In Inlet Air Temperature (IAT) Sensor Failure Mode False
Operating In Throttle Position Sensor (TPS) Failure Mode False
Operating In Pedal Position Sensor (PPS) Failure Mode False
Idle Air Control (IAC) Has Been Monitored Since Power-Up False
Manifold Absolute Pressure (MAP) Sensor Input Is Currently Unreliable False
Engine Oil Temperature Sensor Input Is Currently Unreliable False
Additional Power Takeoff (PTO) Request Switch Input (Additional To DID F41E Bit 0) Inactive
Power Takeoff (PTO) Indicator Lamp/Display Inactive
Power Takeoff (PTO) Indicator Lamp/Display Output Fault Detected False
Learned Throttle Angle Offset (Trim) Learning Incomplete True
Module Power Sustain Relay Commanded state Off
Positive Crankcase Ventilation (PCV) Heater Control B (PCVHC-B) Output Fault Detected False
Positive Crankcase Ventilation (PCV) Heater Control (PCVHC/PCVHC-A) Output Fault Detected False
Inlet Manifold Tuning Valve Open
Intake Manifold Runner Control (IMRC) Commanded State Closed
Intake Manifold Runner Control (IMRC) Output Fault Detected False
Intake Manifold Tuning Valve Output Fault Detected False
The Strategy Has Finished Learning The Inferred Alcohol Content Of The Fuel False
One Touch Intelligent Start (OTIS) Feature Is Disabled; Key Must Be HELD In The START Position For Starter Motor To Operate False
Starter Motor Control Sensed (SMCS) is commanded ON (Indicates/Signals That Starter Motor Operation Is Occurring Or Imminent). False
Starter Motor Relay Is Enabled (The Circuit Has Been Commanded Closed On At Least One Side Of The Relay Coil) False
Pedal Position Sensor Voltage - Sensor 1 0,7822265625 V
Pedal Position Sensor Voltage - Sensor 2 0,3974609375 V
Throttle Position Sensor Voltage - Sensor 1 4,283203125 V
Throttle Position Sensor Voltage - Sensor 2 0,7197265625 V
Program Flow Trace Information - 1 00000000
Program Flow Trace Information - 2 00000000
Distance Traveled Since The Initial Snapshot Was Captured For This DTC 1335 km
Distance Traveled Since This Snapshot Was Captured 10 km
Number Of Faulted Trips Since The First Snapshot Was Captured For This DTC 9
Engine RPM 961 Rpm
- Hoffis
Re: P0131: O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
1 lambda bude KO, nebo poškozená kabeláž. V každém případě to zkontroluj, nebo vyměň lambdu. Špatná přední lambda ti může zničit mimo jiné katalyzátor.
Mondeo MK5 - 2.0TDCi - 132KW
- mivi
Děkuji moc za reakci. Tak to bych nerad nechal zničit rok starý katalyzátor... Je "Bank 1 Sensor 1" ta horní sonda? V dílech označované jako ČIDLO - HEGO 1886204? Je to vyměnitelné bez toho speciálního klíče?
- mivi
Takto vypadala moje horní (přední) lambda po vymontování. Dá se z té barvy něco přímo usoudit?
Nikde nemohu najít zapojení pěti drátové lambdy s těmito barvami:
1 - červená
2 - žlutá
3 - bílá
4 - šedá
5 -
6 - černá
Mezi šedou a bílou je 3,4 Ohmu, to si myslím, že je vyhřívání?
Na čem měřit signál černá - žlutá?
Je po výměně nutné resetovat PCM?
1 - červená
2 - žlutá
3 - bílá
4 - šedá
5 -
6 - černá
- mivi
Ford Focus MK3, 1.0 EcoBoost 92 kW
- mivi
Vracím se ještě k té barvě mé přední lambdy před výměnou.
Narazil jsem na článek s obrázky:
http://autoprollc.com/wp-content/upload ... -guide.pdf
Té oranžové je asi nejblíže tento popis:
"Shiny, dark grey deposits.
Cause: Contamination due to use of leaded fuel.
Lead attacks the platinum which is present both
on the sensor element and in the catalyst.
Solution: Remove the leaded fuel from the
vehicle, and refill with lead-free fuel.
Replace the sensor."
- reckoname
Je asi blbost aby jsi tankoval olovnaté palivo. Dneska jsem měl lambdu taky vytaženou a byla celá černá, jak ta tvá u závitu.
FF4, 1.0L EcoBoost, 114 kW, ST Line, Bílá
Byl:
FF3, 1.0L EcoBoost, 92 kW, Trend Sport, Red Candy
FF2, 1.6, 74kW
FF1, 1.6, 74kW
Byl:
FF2, 1.6, 74kW
FF1, 1.6, 74kW
- mivi
Také si myslím, že jsem olovnatý benzín netankoval...
Dával jsem to sem, zda nemá někdo zkušenost s podobnou barvou.
matejsid
Neviem či ťa to upokojí ale ja mám taký odtieň za turbom. Ecoboost 2.0 177kW
- mivi
Barva je podobná. Já nevím, já jsem lambdu (možná tedy zbytečně) preventivně vyměnil, nechtěl bych aby odešel zase katalyzátor. Už mi ho jednou na záruku měnili. Chyba se mi po výměně lambdy znovu neukázala. Je ale pravda, že jsem kamarádovi stejnou chybu na stejném autě také už jednou mazal a od té doby se mu neprojevila a nic neměnil.
