nejdou budiky + tacho, kontrolky a palubak jdou
vitamarousek
Re: nejdou budiky + tacho, kontrolky a palubak jdou
Příspěvek od vitamarousek » 19.04.2017 14:22
Níže je trochu zkrácený výpis z FORScanu. Stáhnul jsem si elektrická schemata pro FFII, abych se podíval, jak spolu můžou jednotlivé chyby souviset, ale jsem v těch plánech naprosto ztracený :nixw:
Kód: Vybrat vše
===PCM DTC P0231-63===
Code: P0231 - Fuel pump secondary circuit Low
Additional Fault Symptom: Signal is Above Maximum Threshold
Module: Powertrain Control Module
Diagnostic Trouble Code details: Fuel pump secondary circuit Low, The FP is commanded ON, but the secondary circuit monitor (returned over CAN) reports the pump is OFF.
===END PCM DTC P0231-63===
===PCM DTC P0571-63===
Code: P0571 - Brake Switch A Circuit
Diagnostic Trouble Code details: Brake Switch A Circuit, Noise on the CAN derived signal is greater than the calibrated limit., CAN message times out. Fault status reported over CAN. The number of BLS transitions with no BPP switch transitions exceeds the calibrated limit.
===END PCM DTC P0571-63===
===PCM DTC P2121-63===
Code: P2121 - Throttle/Pedal Position Sensor/Switch D Circuit Range/Performance
Diagnostic Trouble Code details: Throttle/Pedal Position Sensor/Switch D Circuit Range/Performance. APPS1 fault., The CAN message from the cluster is missing. The PCM receives APPS1 signal over the CAN network.
===END PCM DTC P2121-63===
===OBDII DTC None===
===ABS DTC None===
===EPS DTC U0155-20===
Code: U0155 - Lost Communication With The Instrument Panel Cluster Control Module
Module: Electronic-Controlled Power Steering
===END EPS DTC U0155-20===
===IC DTC U1900-20===
Code: U1900 - CAN Communication Bus Fault - Receive Error
Module: Instrument Cluster
Diagnostic Trouble Code details: CAN Communication Bus Fault - Receive Error
===END IC DTC U1900-20===
===RCM DTC U0155-20===
Module: Restraint Control Module
===END RCM DTC U0155-20===
===ACM DTC None===
===GEM DTC None===
Ford Focus II Combi Duratec 1.8, rv.2010
vitamarousek
Příspěvek od vitamarousek » 07.06.2017 21:47
Snad to nezakřiknu, ale teď už máme nějakou dobu klid...
V servisu mi jako poslední příčinu mezi řečí označili nějaký špatný pin na svorkovnici GEMu. Prý to mohlo i odstřelovat všechny ty budíky, které jsme tam měli. Nicméně se od nich stále snažím zjistit úplně konkrétně, co bylo špatně. Jde to ale ztěžka, na našem Focusovi si vylámalo zuby několik techniků a nejsou schopni se domluvit s tím pravým :-/
dusanlulka
Příspěvek od dusanlulka » 22.10.2020 23:17
Par mesiacov dozadu mam divny problem.
Po zapnuti zapalovania sa aj na zohriatom motore zozsvieti kontrolka zhavenia.
Po nastartovani zhasne ale zostane svietit kontrolka motora cca.5-10 sek. a nejde ani otackomer, cez diagnostiku otackomer ide.Stalo sa aj ze prerusi po cca.0.5 sek.start alebo coraz castejsie startovanie blokuje.Pravda je ze spinacka je dost rozlogana.Neviem ci je to len môj subjektívny pocit ale startuje nejako spozdene.Otocim kluc na start 0.5sek nic a potom startne.
Inac vsetko ide uplne normalne a dianostika mlci.
Pocas jazdy zatial vsetko normalne.ale ako dlho?
m.osinek
blikající kontrolky na palubovce
Příspěvek od m.osinek » 25.10.2020 10:50
vlastním ford focus mk1,včera mi začaly blikat jak kontrolky tak i pohybovat ručičky tachometru a otáčkoměru na budíku na palubové desce,zkoušel jsem dobít baterku,ale žádný zlepšení nebylo ,bude stačit vyměnit budík nebo to může být i nějaký špatný relátko?nebo něco v řídící jednotce?
dusanlulka
Příspěvek od dusanlulka » 30.10.2020 14:23
Vyriešene:spínačka, elektricka čast.(cekom som sa obaval ze to budu budiky uz nenaskocili ani km. len ciarky)
Demontoval som aj vlozku zamku lebo je problem pootocit kluc do polohy 1
Skusal som to rozobrat ale neslo to,(samozrejme ze som netlacil na pilu) poradite?
hihi
Příspěvek od hihi » 07.11.2020 20:54
Tak se podělím o nejnovější závadu.
Kromě ručiček vše ostatní na přístrojovce zhasne. Nejde podsvícení, při odbočování nesvítí kontrolky blinkrů, nesvítí displej. Všiml jsme si toho před pár dny. Zjara (?) jsem přepájel kontakty drátů vedoucích do přístrojovky, protože to blblo. Evidentně budu hledat další studeňák, který způsobuje, že rafičky svítí jako jediné. Kdyby někdo věděl, kam s pájkou sahnout, budu rád. Díky :-)
FF MK3, 2015, 1.5 TDCi 88 kW
byl FF kombi 09,TDCi,66kW+DPF
hihi
Příspěvek od hihi » 18.11.2020 20:02
Sháním schéma (napájení) budíků FF II po FL. Občas zhasne mi vše mimo ručiček. Diagnostika nehlásí žádnou chybu. Takže někde ztrácím + nebo zem a potřebuji odhadnout, co přepájet :-(. Pomůžete mi schéma najít? Díky.
edit: propájel jsem vstupní kontakty (na jaře kvůli klasickým chybám v PCM), do dalších součástek se mi nechce, na to nemám technologii (horkovzduch?). Uvidíme, jestli to bylo tam. Na vstupu jsou tři země, kdyby jedna byla "studená" mohlo by to možná dělat tuhle chybu. To ale hádám.
Naposledy upravil(a) hihi dne 18.11.2020 22:30, celkem upraveno 1 x.
Příspěvek od ZaQik » 18.11.2020 20:08
el. schema focus 2009 z viewtopic.php?f=53&t=11711 a tam strana 82 a 70
fotopetr
Příspěvek od fotopetr » 19.11.2020 08:37
Zemí to nebude. Diagnostika nic nenajde, protože se s budíky nedomluví, nejde sběrnice. Zkontroluj konektor.
hihi
Příspěvek od hihi » 19.11.2020 11:44
ZaQik: díky :-).
Fotopetr: Děje se to výjimečně, ale vždy se stejnými symptomy a mezi ně patří to, že datové kabely do budíků jsou OK, jinak by diagnostika hlásila chyby z toho plynoucí. Pouze občas přestala svítit část osvětlení přístrojovky, bouchnutí do kapličky to vždy vyřešilo. Prostě klasika - studeňák. Přepájení konektoru mám zjara za sebou, možná blbě. To by byla ta lepší varianta.
Propájel jsem včera celý konektor, k tomu z opačné strany dvě diody (při měření mi jedna z nich házela sem tam podivnosti, což lze přičíst špatnému kontaktu multimetru, ale za propájení nic nedám), před chvíli jsem to nacpal do auta, nasadil za běhu ručičky a uvidím, jestli to bude ok, nebo je to na desce jinde. A to bych už asi nedal.
Tak uvidím. Za info o stranách ve schématech moc díky!
edit: Jestli čtu schémata správně (prokousávám se tím hodně pomalu), tak to mohl být studeňák na pinu č. 6 (GND) na konektoru. Začínám být mírný optimista, co se nalezení příčin týká a tím i odstranění závady.
hihi
Příspěvek od hihi » 27.11.2020 18:29
A jsem zase na začátku. Přímo na konektoru to nebylo. Blikáme dále. Alespoň to umožnilo zjistit přesně, co nesvítí - podsvícení a k tomu se občas přidá červená vločka. Nezávisle na sobě. Jdu prolézt desku...
hihi
Příspěvek od hihi » 28.11.2020 23:48
Přepájel jsem kondenzátory za piny 9,10,11. A závada trvá. Někde je studeňák a v důsledku nesvítí podsvícení budíků a zaregistroval jsem to i pro červenou vločku (ne pro oranžovou, ta svítí stále). Propájet celou desku je nad moje možnosti. Poradí někdo, kam sáhnout? Kupovat nové budíky nebudu, protože nemám dva klíče, takže bych musel do servisu nechat přihlásit budíky do řídící jednotky. To si snad raději zvyknu, že to někdy nejde.
takhle se to chová (2x - 4x zpomaleno): https://youtu.be/Ufs4mbFQ8fc
holá deska (sem tam mám vyznačené schéma podsvícení)
https://ulozto.cz/tamhle/L5ZuhF1GJ7vG
Za radu bych byl vděčný :-). Ale elektrotechniků, kteří to řešili a vyřešili tu asi moc nebude. Kdybych měl horovzduch (opalovací pistole na to fakt nebude), tak bych se do toho asi dal. Ale mikropájkou? Spoj po spoji... No. Máte někdo s tímhle zkušenost?
EDIT úvaha: podsvícení se rozsvěcí s mírným zpožděním za rafičkami. Na desce jsou u sebe dvě diody. 2201A3 a vedle 148A. Při zkoušce funkčnosti v závěrném směru je 14A8 pár sekund průchozí, pak se zavře. Další stejné jinde na desce to nedělají. Pokud to není chyba a já myslím, že ne, tak je tam nějaký pomocný obvod, který to dělá a je to třeba něco s tím zpožděním podsvícení. Co kdyby se ten obvůdek aktivoval ... Anebo je to chyba a je tu jádro pudla. Budu ji muset odpájet... Rady prosím...
Na fotce je zakroužkovaný kondenzátor, který je bezprostředně za pinem 9 a zmíněná dioda 148A (to je na ní napsáno).
fotopetr
Příspěvek od fotopetr » 29.11.2020 05:52
- Když máš tu desku na stole, připoj ji na napětí a měř rovnou na těch LED diodách.
- Pokud to bude studeňák, bude nejspíš vidět. Pokud máš mikroskop, dá se najít. Pokud nemáš, můžeš zkusit lupu s velkým zvětšením.
- takhle se může chovat i špatný prokov (i ten se dá opravit) a těch je na této desce mraky, proto na tom potřebuješ měřit v "dobrém" i "špatném" stavu.
hihi
Příspěvek od hihi » 30.11.2020 01:54
Když mi někdo na 110 % řekne, kde je "přívodní" pin pro podsvícení. Já myslím, že 9. Ale jistotu nemám a když ji nemám, tak to neudělám. Já myslel spíš, že ze struktury obvodu ledek (a ochranných rezistorů) vymyslím, kde to začíná. Ale ztratil jsem se. Ale když to připojím, aby svítilo podsvícení, tak to rozhodně půjde poklepem dohledat taky. Takže kam dát +12V? (Budu to dělat až v pátek, aktuálně jsou budíky zpátky a jezdí se).
A vlastně mikroskop tu mám taky. Ale s jeho hloubkou ostrosti to asi nebude nic moc ...asi lepší, než pájet nazdařbůh.
Příspěvek od ZaQik » 30.11.2020 09:42
je to pin 9
Zpět na „Focus - budíky (palubní počítač, kontrolky)“
